so my apache has decided it doesnt like starting when i press the button its just makes a clicking sound what could this be from and how to fixe me and few friend got a long ride out on sunday so need it fixing by then
Weak battery. Recharge or replace.
^ +1
Your battery is not carrying a charge for which ever reason. Try recharging the battery first and see how it goes. Be mindful that a discharging battery or one not able to hold a charge (whatever the cause) might leave you stranded some place - so be prepared for that eventuality. If the battery is not holding a charge - replace it with a new one.
so i charged the battery and now it isnt starting at all its ticking over but not firing up
So, you obviously have the kill switch on, choke on and you aren't touching the throttle while cranking. Then it is time to look for gas in the carb and spark from the plug.
HI there mate i add a problem with my apache the other day. So in the end it turnt out to be the spark plug. I was getting a really weak spark. But i was also told that it might have been the ignition coil. So try either one of them mate.
