derestricting lexmto street
Can anyone help
i have just bought a lexmoto street 12 plate only 700 m on the clock great little runner untill i hit 5th gear and it totally stops at 60, i can tell it still has more play in it however not sure on wear these bikes are restricted????????????????
Re: derestricting lexmto street
Try the almost FREE mod 1st. Throw the CATs (1 in head pipe & 1 in can) if u can weld ...
sorry caould you explain a little more please mechanics arent that good
"human being" tells you to "amputate" catalytic converters from exhaust pipe and muffler.
I have a Sinnis Max which is near identical to your Lexmoto Street and my stock exhaust does not have a catalytic converter in it so I would assume that you don't have one either.
These bikes are not restricted.
For a tad more power get a 28mm carb and change your front sprocket for a 16 tooth. As for the exhaust you can't buy performance exhaust systems locally so buy a performance exhaust can made for another 125cc - 250cc bike, cut your old one off where the pipe meets the can and have a mechanic weld it on.
