hoping someone can help me with this i dont have an owners manual and ive found bits and pieces but where is the oil filter located and how does one go about changing the oil and filter on this 250 rtc?
Oil filter location is on the left had side of the engine under the flywheel casing.
To change the oil, first you need to remove the drain bolt on the underside of the engine (make sure you have a big enough pot underneath ready) if it doesn't have a centre stand you will need to hold the bike upright to drain all of it.
Then undo the oil filter nut, remove the spring and filter and give it a good clean (you won't need to change it unless it has a split)
If you need any more help I'll do my best.
awesome thank you for your help
