Jialing JH250 performance upgrade
I'm one of 6 or seven owners of JH250E5 cruisers in Harare, Zimbabwe. I've reduced the rear sprocket to 29 teeth to give a theoretical 140kmh @8500rpm but need a bit more torque. We're at 1500m above sea level, so I need smaller main jets than the 98s fitted, but can't find anything here. Has anyone played with one of these to get a bit more power? They are a clone of Honda's CB250, which is rated at 15Kw - but theJialing version only produces 12Kw. If no-one's attacked their motor yet, I'll carry on and keep you informed of progress.
More on the 250 performance
Thanks to iamcanjim for the Rebel-derived info - I see you guys have a huge site. My problem is not too lean a mixture, but too rich. Even with the head-work the beast still runs rich at full throttle. I'll find some smaller main jets somewhere, but there are limited suppliers here in Zimbabwe. The only other hassle I have is the quality of drive-chains - I've destroyed 2 in 6000 kms (and I do lube them and adjust them). One broke on 4000 ks and the next shed its rollers. Obvious answer is proper o-ring chains but I'm being quoted +/- US$100 a time! Just done an 1100km trip in company with half-a-dozen others, none on less than 750cc bikes, and it held its own, unless there was a headwind or a steep slope. I mounted a GPS for the trip, and recorded a max true speed of 120kmh and an average moving speed of 80kmh, which aint bad! I'm still enjoying, which is the main thing.
