Help with CG200 wiring harness please
Hello all.
Recently decided to pick up a project bike. Just by googling, seems its a 200GY or CG200. Engine stamp says HS163FML.
Going to strip all the broken lights, gauges etc. Needing to figure out what basic wiring harness I can use on this. The cdi was missing on this and the plug cut off.
I included a pic of the stator wires if that helps. This original harness is hacked up.
Can I use this AC 6 pin CDI complete harness seen HERE?
Any help is greatly appreciated. Thanks
http://i.imgur.com/cTZLUaQl.jpg
http://i.imgur.com/wvEE4qjl.jpg
http://i.imgur.com/4QmPRiRl.jpg
The wide plug is coming form the stator. What is this green plug?
Re: Help with CG200 wiring harness please
I ordered a couple wiring kits, hopefully I can figure it out. If anyone has any info id greatly appreciate the help.
Gonna need cleaned up.
http://i.imgur.com/Fntgc3sl.jpg
Clutch side seems OK
http://i.imgur.com/kqwUZpnl.jpg
http://i.imgur.com/NheFtBwl.jpg
Found seals and gaskets for it. I would like to see this baby rip again.
G'day RPB - welcome to MCM :icon10:
Not sure if you've done any search via g00gle on 200GY or CG200 or HS163FML (can add mychinamoto' to any search which should provide you all posts/threads posted here on MCM) - works better than doing a search directly using the MCM search-engine.
Also, it might be worth joining/posting your questions on Chinariders as there's a concentration of riders of all things Chinese/bikes, stateside.
Worth updating this thread on your progress too...
:popcorn:
