- TUTORIALS: DEPTH OF FIELD -
Depth of field is the range of distance within the subject that is acceptably sharp. The depth of field varies depending on camera type, aperture and focusing distance, although print size and viewing distance can influence our perception of it. This section is designed to give a better intuitive and technical understanding for photography, and provides a depth of field calculator to show how it varies with your camera settings.
http://www.cambridgeincolour.com/tut...pthoffield.jpg
The depth of field does not abruptly change from sharp to unsharp, but instead occurs as a gradual transition. In fact, everything immediately in front of or in back of the focusing distance begins to lose sharpness-- even if this is not perceived by our eyes or by the resolution of the camera.
http://www.cambridgeincolour.com/tut...ensdiagram.png
Since there is no critical point of transition, a more rigorous term called the "circle of confusion" is used to define how much a point needs to be blurred in order to be perceived as unsharp. When the circle of confusion becomes perceptible to our eyes, this region is said to be outside the depth of field and thus no longer "acceptably sharp." The circle of confusion above has been exaggerated for clarity; in reality this would be only a tiny fraction of the camera sensor's area.
http://www.cambridgeincolour.com/tut...fconfusion.png
When does the circle of confusion become perceptible to our eyes? An acceptably sharp circle of confusion is loosely defined as one which would go unnoticed when enlarged to a standard 8x10 inch print, and observed from a standard viewing distance of about 1 foot.
http://www.cambridgeincolour.com/tut...dofmarkers.png
At this viewing distance and print size, camera manufactures assume a circle of confusion is negligible if no larger than 0.01 inches (when enlarged). As a result, camera manufacturers use the 0.01 inch standard when providing lens depth of field markers (shown below for f/22 on a 50mm lens). In reality, a person with 20-20 vision or better can distinguish features 1/3 this size or smaller, and so the circle of confusion has to be even smaller than this to achieve acceptable sharpness throughout.
A different maximum circle of confusion also applies for each print size and viewing distance combination. In the earlier example of blurred dots, the circle of confusion is actually smaller than the resolution of your screen for the two dots on either side of the focal point, and so these are considered within the depth of field. Alternatively, the depth of field can be based on when the circle of confusion becomes larger than the size of your digital camera's pixels.
Note that depth of field only sets a maximum value for the circle of confusion, and does not describe what happens to regions once they become out of focus. These regions also called "bokeh," from Japanese (pronounced bo-ké). Two images with identical depth of field may have significantly different bokeh, as this depends on the shape of the lens diaphragm. In reality, the circle of confusion is usually not actually a circle, but is only approximated as such when it is very small. When it becomes large, most lenses will render it as a polygonal shape with 5-8 sides.
CONTROLLING DEPTH OF FIELD
Although print size and viewing distance are important factors which influence how large the circle of confusion appears to our eyes, aperture and focal distance are the two main factors that determine how big the circle of confusion will be on your camera's sensor. Larger apertures (smaller F-stop number) and closer focal distances produce a shallower depth of field. The following depth of field test was taken with the same focus distance and a 200 mm lens (320 mm field of view on a 35 mm camera), but with various apertures:
http://www.cambridgeincolour.com/tut...image1-f56.jpg
CLARIFICATION: FOCAL LENGTH AND DEPTH OF FIELD
Note that I did not mention focal length as influencing depth of field. Even though telephoto lenses appear to create a much shallower depth of field, this is mainly because they are often used to make the subject appear bigger when one is unable to get closer. If the subject occupies the same fraction of the viewfinder (constant magnification) for both a wide angle and a telephoto lens, the total depth of field is virtually* constant with focal length! This would of course require you to either get much closer with a wide angle lens or much further with a telephoto lens, as demonstrated in the following depth of field chart:
Focal Length (mm) Focus Distance (m) Depth of Field (m)10 0.5 0.482
20 1.0 0.421
50 2.5 0.406
100 5.0 0.404
200 10 0.404
400 20 0.404
Note: Depth of field calculations are at f/4.0 on a Canon EOS 30D (1.6X crop factor),
using a circle of confusion of 0.0206 mm.
Note how there is indeed a subtle change for the smallest focal lengths. This is a real effect, but is negligible compared to both aperture and focus distance. Even though the total depth of field is virtually constant, the fraction of the depth of field which is in front of and behind the focus distance does change with focal length, as demonstrated below:
Distribution of the Depth of Field
Focal Length (mm) Rear Front
10 70.2 % 29.8 %
20 60.1 % 39.9 %
50 54.0 % 46.0 %
100 52.0 % 48.0 %
200 51.0 % 49.0 %
400 50.5 % 49.5 %
his exposes a limitation of the traditional DoF concept: it only accounts for the total DoF and not its distribution around the focal plane, even though both may contribute to the perception of sharpness. A wide angle lens provides a more gradually fading DoF behind the focal plane than in front, which is important for traditional landscape photographs.
On the other hand, when standing in the same place and focusing on a subject at the same distance, a longer focal length lens will have a shallower depth of field (even though the pictures will show something entirely different). This is more representative of everyday use, but is an effect due to higher magnification, not focal length. Longer focal lengths also appear to have a shallow depth of field because they flatten perspective. This renders a background much larger relative to the foreground-- even if no more detail is resolved. Depth of field also appears shallower for SLR cameras than for compact digital cameras, because SLR cameras require a longer focal length to achieve the same field of view.
*Note: We describe depth of field as being virtually constant because there are limiting cases where this does not hold true. For focal distances resulting in high magnification, or very near the hyperfocal distance, wide angle lenses may provide a greater DoF than telephoto lenses. On the other hand, for situations of high magnification the traditional DoF calculation becomes inaccurate due to another factor: pupil magnification. This actually acts to offset the DoF advantage for most wide angle lenses, and increase it for telephoto and macro lenses. At the other limiting case, near the hyperfocal distance, the increase in DoF arises because the wide angle lens has a greater rear DoF, and can thus more easily attain critical sharpness at infinity for any given focal distance.
CALCULATING DEPTH OF FIELD
In order to calculate the depth of field, one needs to first decide on an appropriate value for the maximum allowable circle of confusion. This is based on both the camera type (sensor or film size), and on the viewing distance / print size combination.
Depth of field calculations ordinarily assume that a feature size of 0.01 inches is required for acceptable sharpness (as discussed earlier), however people with 20-20 vision can see features 1/3 this size. If you use the 0.01 inch standard of eyesight, understand that the edge of the depth of field may not appear acceptably sharp. The depth of field calculator below assumes this standard of eyesight, however I also provide a more flexible depth of field calculator.
DEPTH OF FOCUS
Another implication of the circle of confusion is the concept of depth of focus (also called the "focus spread"). It differs from depth of field in that it describes the distance over which light is focused at the camera's sensor, as opposed to how much of the subject is in focus. This is important because it sets tolerances on how flat/level the camera's film or digital sensor have to be in order to capture proper focus in all regions of the image.
OTHER NOTES
Why not just use the smallest aperture (largest number) to achieve the best possible depth of field? Other than the fact that this may require prohibitively long shutter speeds without a tripod, too small of an aperture softens the image by creating a larger circle of confusion (or "Airy disk") due to an effect called diffraction-- even within the plane of focus. Diffraction quickly becomes more of a limiting factor than depth of field as the aperture gets smaller. Despite their extreme depth of field, this is also why "pinhole cameras" have limited resolution.
For macro photography (high magnification), the depth of field is actually influenced by another factor: pupil magnification. This is equal to one for lenses which are internally symmetric, although for wide angle and telephoto lenses this is greater or less than one, respectively. A greater depth of field is achieved (than would be ordinarily calculated) for a pupil magnification less than one, whereas the pupil magnification does not change the calculation when it is equal to one. The problem is that the pupil magnification is usually not provided by lens manufacturers, and one can only roughly estimate it visually.
OTHER WEBSITES & FURTHER READING
* Norman Koren provides another perspective on depth of field, including many equations for calculating depth of field and the circle of confusion
* The Luminous Landscape compares the depth of field for several focal lengths-- providing visual proof that depth of field does not change with the focal length.
http://www.cambridgeincolour.com/tut...h-of-field.htm
