2009 Qlink XF200 fork seals needed
Does anyone know if a Qlink XF 200 Fork seal will interchange with a 2004 Suziki DR200 SE.
I looked up Rocky Mountain Parts website for Suzuki DR 200 and it listed the MSR forks that I have seen in Qlink Blogs about parts interchanging. Anyone know for sure if they will work? That would be the quick and easy and probably a little better quality.
I want to figure out what parts will work off a Suzuki DR 200 and exactly which year.
What is the difference of a DR200 and DR200SE?http://www.mychinamoto.com/forums/im...cons/icon6.png
Florida Larry
Re: 2009 Qlink XF200 fork seals needed
Does your XF200 have inverted forks?
If you remove the seals, they will have the dimensions printed on them and you can probably match them quite easily.
Yes my bike has inverted forks. I saw where the Suzuki DR200SE has the same brand inverted forks so I thought it would be a good chance they matched.
Florida Larry
Cab4less
Florida Larry
I don't think so. Can you show me an example of a DR200 with inverted forks?
http://pictures.topspeed.com/IMG/cro...0se_460x0w.jpg
http://cgi.ebay.co.uk/Fork-Seals-41x...#ht_1832wt_946
Just bought a set myself :)
Hope this helps :icon10:
DaNjamin
