150cc piston spec
		Does anyone know the specs of the 150 piston for the rmr125 style bikes (size, gudgion pin sze etc..)? Is it possible to buy the pistons seperately? I ask because i would prefer to get my current barrel bored out instead of buying a 150 one, because i can get it done free at a freinds workshop.
thanks
Re: 150cc piston spec
		That chinese 150 kit in fleabay = diameter: 62mm / pin: 14mm
There's also weird solultion using Honda clone  -- CG150/ CB150  (62mm/15mm) kit :naughty:
http://www.motorfans.com.cn/bbs/t_432525_1.htm
		hi humanbeing, thanks alot for the info, very helpful :) .the CG kit might be a bit too much work though :L Do you know the deck height of the piston? (top of  pin to top of piston)
thanks
		125: 57 * 48.8 / Pin: 14mm
150 =  EN/GSX/GZ 150 CRANKSHAFT   57 * 56.8 /Pin: 15mm OR 62mm "kit"
172 =  GY6 62mm piston  *    "56.8" CRANKSHAFT
http://www.motorfans.com.cn/bbs/view...uthorid=108220
191 = 65.5 piston *   "56.8" CRANKSHAFT
http://www.motorfans.com.cn/bbs/view...A3%C5%D6%D7%D3
Some piston info written by that "fatty" above:
http://www.motorfans.com.cn/bbs/view...=108220&page=4
