Re: qlink xp200 tire ware
The drum brake will transfer more heat, do you use the rear brake? I ask because some say they do not and they really should use both and if the brake is binding it will transfer heat, check the service manual to see how much play the rear brake should have, if the play is not correct loosen the rear brake till it is correct.
The service manual also covers chain adjustment and you should have guides on both sides. Wonder why one is missing?
Do your sprocket show wear?
I always measure from the center of the swing arm pivot point, to the center of the rear axle bolt.If the chain is tight in places and loose in others,the chain is bad.Most likely the chain has stretched unevenly.
