good easy mod for superbyke rsr/rmr 125
if you look at your airbox there should be two inserts one holds your sponge filter in place the other smaller tube actually restricts the airflow to your carb so remove the smaller tube but keep the filter tube in there to keep crap out your carb.
yuo will need to adjust your idle valve and adjust the screw at the bottem of the mikuni carb just remember you will need to test it every adjustment to get it right and only turn the screws a quarter of a turn for each adjustment
Re: good easy mod for superbyke rsr/rmr 125
Any chance of a picture? I have a pulse adrenaline. I dont remember seeing anything like that in my airbox??? Cheers
will have the tank off on tuseday ill take the side panels off and take a quick snap mate might bnot have the same airbox if u could get a pic on here aswell ill see if i can do anything for you
just so you know i can build a custom air filter at cos of materials plus postage
how much would it cost for the air filter? and how much work needs doing?
