for a 2008 TMEC 125 SM?
http://a6.sphotos.ak.fbcdn.net/hphot..._7741458_n.jpg
I'm currently in the process of buying one and it's screaming out for some front end fondling.
front end wise ur looking at pulse adrenanline or sinnis apachi gold annodised
depending on the weight of your Tmec you could get a set of Derbi senda 50 forks since there about the size of a 125 supermoto/enduro would be better made being european plus i know that chinese made gold forks will fade especially on the fork thats exposed when the steering lock is engaged varying from generic trigger SM 50- Pulse adrenaline's
This thread has been in-active for years so its a longshot but someone said that you could put derbi senda forks or pulse adrenaline forks on a tmec 125 so would i be able to put the pulse adrenaline forks on a derbi senda if i use the adrenaline yokes or do they have different head bearings?
Corey you would have to check the diameters and length of the forks honestly would be better finding a damaged SM PRO Senda to swap the front
