Help!!!!!!!!
My Qingqi 200gy is not starting but the hooter & lights are going on.What might the problem be?
This my 1st bike & really don't know what to do
Help!!!!!!!!
The three most likely culprits are:
1. No gas (switch the petcock to reserve tank, just to be sure - it's the metal valve on the side of the bike (type petcock into google images to see a picture). It should be pointing down to use the reserve tank. Don't forget to turn it back after you fill up!
2. Dead battery - sounds like the battery is OK if the lights are working
3. Dead spark plug - the tools you need to replace it are on the back of the bike, in a little black tube above the back tire. It's straightforward to replace if you have a replacement.
Have you tried to push start it? Put it in gear, hold the clutch, get the bike rolling, and then release the clutch. That should start the engine - if that works, then it's not a spark plug or gas problem. Good luck!
90% of not starting problem from the electronic issue.
If you have gas in your tank, than you should take out the spark plut to see if it fire or not.
Check your fuse !
