Any thoughts or experience with this bike?
Good Bad.....
Attachment 8611
Attachment 8612
Attachment 8613
Product Description:
High demand high standards of manufacturing attitude prompted us to build out a will make you bikers amazing works! This car at first glance, and Xinyuan 200GY-7 Long March is no different from the basic appearance and use pieces is in accordance with the shape of the Long March to build, but the damping we adopt cabbage damping because Kawaminami had this car returning to the Jialing cabbage paragraph, maybe everyone is seen Oh! By road test results show that indeed the performance is quite good huh manipulation and overall coordination is very good, which is what we want results! Some with pieces: before Houchuan Nan First grade damping increase the Xinyuan Changzheng dedicated fuel tank custom lengthened cushion front disc brakes with dual calipers pump body iron the the silver bowl headlight bull headlights Zhenglin the retaining frame bull handlebar overbearing widening strengthen the shelf around the Giant alloy ring the Changqing wheel hub reducers wire bold circuit system and the three letters Lihua electrical otherwise noted this car modified the xenon headlights basic introductions!
Vehicle specific parameters
Vehicle color: red, dark green with elegant black (the appearance of color can be customized according to the riders needs)
Engine type: single-cylinder, four-stroke, air-cooled
Displacement: Zongshen 250 whiteboard machine
Transmission: manual clutch / 5 file before step 1N hook up 2345
Starting Mode: Electric foot dual boot
Carburetor: Plunger caliber PZ27/30
Lubricants: 4T 15w/40
Ignition way: C, D, I electronic ignition
Direction: independence pine adjustable handlebar
Front suspension: Kawaminami first-class products specially damping
Rear shock: Kawaminami First grade specially
1.85 - 21 2.15-18 alloy wheels front and rear wheels (the colors white, black, blue, gold, purple, red)
Front and rear tires: 80/100-21 110/100-18 dual-use terrain tires
Seat height: 850 ± 5mm (riders height to replace the wheel size to adjust the height)
Vehicle Dimensions: 2070x865x1100mm
Fuel tank capacity: 18L
Net Weight: 130kg
Permitted to carry: 2
Top speed: 120km / h 250CC (based on the need to deploy)
Greg
