hi folks was wondering if u could help my indicators down work on my rmr one side comes on but doesnt flash the other side doesnt come on at all could it be the flasher relay?
Bulbs? Do you have both front and rear switch on on the one side, or only one of them?
d/l & read the "200" manual http://www.mychinamoto.com/forums/showthread.php?2565
sounds like a dodgy flasher unit... since you've checked the bulbs, and I assume fuses then that would be my next 'port of call' aside from using a multimeter to check each section of wiring including the switch block.
