Sinnis Aoache 125 idle help
Hi there i am stuck and need help with my 125. When i start the bike it revs really high between 3-5000 rpm. When i try and put the choke down the bike slowly cuts out. Looked at the carb and i couldn't actually see the idle screw. Its probably there but i don't wanna start playing with screws that could be important. If someone could help me that want be great and would be much appreciated. By the way my apache is a 58 plate if that makes any difference.
Re: Sinnis Aoache 125 idle help
Dear Bradley,
You get any help with this? I seem to remember someone asking a very similar question a week or two ago, and getting some decent advice. Might have been the RMR Superbyke, which I think is a clone of your Sinnis, or vice versa. Like try this thread for starters.
Make sure you have some free play in the throttle, if you dont then adjust it using the adjuster which should be located near the throttle possible covered by a rubber sheath. If that dosen't sort the problem then you can adjust the idle speed using the screw on the side of your carb (not the bottom).
Thanks to everyone who has helped. Much appreciated.
HI there mate sorry its been a while but it still hasnt been fixed. Any other ideas?
