Re: Lexmoto xtr service help
Thanks for that I thought it might be a carb problem and guy I bought it from did say it had been sitting for 8 months unused so could be clogged jet as you said do you no if they would sort that during service? as I'm booked in for 1 in a few days
On the right hand side of the carb there is a screw, with the engine warmed up fully and idling turn the screw clockwise until the idle is at the correct speed of around 1500 RPM.
Failing that adjust the idle mixture screw on the bottom of the carb to achieve the best idle then re-adjust idle to 1500 if necessary.
Failing that remove the carb from the engine, take the bottom place off and clean out everything you can.
Failing that get a new carb they are only cheap ;)
http://www.ebay.co.uk/itm/Carb-NEW-C...item3ccc6ba7c1
