Having a few issues with my Pulse Adren 125
Firstly i brought this bike around 1 week ago and since that the indicators have stopped working correctly, when i press the indicators all lights flash rather then just the one side.
Secondly the battery only lasts around 1-2hours which im taking it to be an bad battery which is only £20-£30 replacement. I did think it was the alternator but then it allowed me to jump start it.
Thirdly today when putting the battery in, and connecting the power connecters (pos first, neg last) the tiny green wire that connects onto the positive side burnt out and now it wont work at all? does anyone know the issue?
How much would it cost me to take it to my local bike shop to get rewired?? thanks
Re: Having a few issues with my Pulse Adren 125
If there are shorts in the wiring loom and wires are burinig out there is probably a bunch of problems with it that are going to be a bit of a pain to fix so if I was you I'd just get a new wiring loom, they are only £60 and I think they are easy to fit. It will probably be cheaper than taking it to a mechanic.
http://www.chinesemotorcyclepartsonl...XF125GY-2B.php
Also are you sure that you got the polarity right on the battery terminals? I have a wiring diagram for the Pulse Adrenaline and it says that there should be a green wire going to the negative terminal and a red to the positive.
Attachment 14791
