Hey people.. is there any possibility of fitting a kick starter to my pulse?
Many thanks
Jordan
Many thanks
Jordan
I have never seen the engine that you have with a kick start so I highly doubt that it is possible.
well my theory is... its based on a popular 125 suzuki engine.. so maybe.. if i got the right parts then there could be a possibility ?
I have no idea but its an idea i am willing to give ago if there is any chance in it actually working...
http://www.mychinamoto.com/forums/showthread.php?2754 | http://www.microsofttranslator.com/b...horid%3D176452
Compare similar 80s Suzi @ http://www.cmsnl.com/ & ur bike will get the basic idea.
Ah so it looks like it can be done. I wonder if there is a gear inside that a kick start could be attached to if a hole was drilled in to the crank case or is it more complicated than that?
From rumors i heard you knock out oil sight glass and it goes in there... i might drain engine tomorrow have a look inside see whats lurking in there
Look what i just found... its clearly possible i guess??
http://www.chinesemotorcyclepartsonl...p?i=XF125GY-2B
Interesting, I didn't know that this existed. I would assume that any bike the the same enging could have it fitted. It would be useful if I could find a picture of the engine with the right crank case cover off to see if it's a simple fit, prehaps when I do my next oil change I will remove the cover and take some photos.
Im opening it up tomorrow well i might as well i am changing oil filter so might as well kill 2 birds with one stone lol i will attach few pics here tomorrow evening but from rumor i heard you take oil sight glass out then that bit goes in there somewhere but i have no clue... i have a Haynes manual for suzuki gs 125 engine which the pulse engine is based on i will have a flick in the book see if i see anything
