3 Attachment(s)
High flow air filter for CFMOTO 650NK and TR
So I was having a look at the OEM air filter:
Attachment 14960
http://detail.tmall.com/item.htm?spm...bf327edc7dd336
See the shape, so then I tried looking for a replacement thinking a K&N Kawasaki ER6N for around 2006-2008 no luck on the K&N site. So I had a look at some other manufacturers and found this:
Attachment 14961
http://www.motospecialties.com/store...mNum=MC-040-06
and this:
Attachment 14962
http://www.motorcycle-exhausts.co.uk...l#.Uw_sMrWoXKB
Obviously you can see the Kawasaki version has a notch not present on the CFMOTO version. So my thoughts are will spending money on the Kawasaki version be worth it? Cut a piece of plastic and epoxy it, would it fit? Looks like a little bit of modification. Or just put up with the stock filter? Although China is a dirty place and some tiny particles will always find their way past a low grade filter and a dirty injectors are always a possibility.
Re: High flow air filter for CFMOTO 650NK and TR
Or one option is to go and use pod filters like some people have done.
Attachment 14963
Wald0
Attachment 14963
Don't like pods, I've had them on other bikes, they screw with the environmental equipment and the vacuum system. I actually prefer my bike to be greener than have the extra power. Also they can cause some nasty air pressure buffeting.
The last few previous bikes I had I did all that carb rejetting, muffler cutting, clip-on filters including the pretty little crank-case filter, I feel I never gained a thing other than a headache and a slightly nicer exhaust sound.
This time I'm just doing subtle legal upgrades, bar upgrade, filter upgrade, iridium plug upgrade, brake pads, nice tires etc. All legal and environmentally friendly. The cops around here are getting heavy on illegal bikes, if they can find anything illegal about your bike they will, 'cause that's money in their back pocket. :naughty:
this picture is off my cfmoto 650nk...i can firm the engine runs better and no longer sucks it hot air from behind the rad.
Wald0
Attachment 14963
pommie
Hi Pommie, a quick question. what was the attachment diameter for your crankcase filter? And how did you get around not mounting the MAF sensor on top of your filters
