Superbyke RMX-125 Spluttering on low RPM?
Hi, ive recently bought a superbyke rmx 125, it starts fine with zero problems, but in first and second gear just as your opening the throttle it starts to splutter a little until yiu open the throttle up then it stops.
ive cleaned air filter but probleem still there.
Any ideas?
thanks
Re: Superbyke RMX-125 Spluttering on low RPM?
Carb's idle and main jet?
Hi, the bike never cuts out, i think the tick over is a little high, but have no adjusted anything yet.
According to that syndrome, 90%+ the idle jet is clogged .
Ah right cheers for the reply, so do you suggest I clean it?
Is this easily done?
Okay, so I took it to the mechanic today (after I cleaned the carb) the mechanic said the problem was the HT lead apparently, he said it must be arching out some where but when ive checked I can't see it arching at all, could this be the problem or ?
Checked the valve clearence?
GENERAL info about these 125 Suzi & clone family:
4 valve http://www.chinariders.net/files/SER...NUAL-GF125.pdf
2 valve SAME procedure as this http://pan.baidu.com/s/1sjqfYlZ 200
[10mm spark plug /C...]
IN: 0.04mm-0.07mm | EX:0.13mm-0.18mm (0.002" /0.005")
[12mm spark plug /D...]
IN:0.08mm-0.13mm |Ex: 0.13mm-0.18mm (0.003" /0.005")
Mechanic's primitive tool that can check the spark condition https://translate.google.com/transla...yes&edit-text=
