3 Attachment(s)
C2W brings you the DAYUN 200-2X Street bike
Attachment 17735
Attachment 17736
Length*Width*Height(mm) 2070*780*1230
Wheel base(mm) 1363
Tread(mm)
Minimum ground clearance(mm) 165
Net weight (kg) 155
Load capacity(kg)
Max. Speed (km/h) ≥95
Brake form(front and rear) disco delantero/ disco trasero
Tire specifications(front and rear) 100/80-17 ; 130/70-17 (KENDA)
Tire pressure(front and rear) (kPa)
Model
Trademark DAYUN
Type solo cilindro enfriado por aire de cuatro carreras
Production unit GUANGZHOU DAYUN MOTORCYCLE CO.,LTD
Bore and stroke(mm) Φ66×57.8
Working volume of the cylinder (ml) 197.6
Compression ratio 9.1:1
The rated power and corresponding speed [kW/(r/min)]
The maximum power and corresponding speed [kW/(r/min)] 10.5/7200
The maximum torque and corresponding speed [N.m/(r/min)] 15.5/5500
The minimum idling stabilized speed (r/min) 1500±150
Minimum specific fuel consumption g/(kW.h)
Fuel type
Grades of lubricant
Clutch Model
Starting mode electric
Ignition
Form/model of Speedometer
Form/model of Carburetor /Injector/ECU
Manufacturers of Carburetor /Injector/ECU
Form/modelof Spark plug
Form/model/Manufacturers of Exhaust pollution control devices
Manufacturers of Air Filter/Muffler(the Sample)
Read latest copy of china2wheels (C2W) at http://cnluwo.com/C2W/01/C2W01.html#p=1
Re: C2W brings you the DAYUN 200-2X Street bike
The DY250-3 is a copy of a Z-250 with a DOHC 250 single.
There are some ranting raves for Dayan in the Chinese media commending them for the design, as if nobody can see it’s a copy?
http://i784.photobucket.com/albums/y.../Dayun/763.png
I see Dayan as a party company, not as in that they are so much fun, more that they spend allot of time spreading party line rhetoric, and not much time detailing what they actually make and sell.
http://imgd1.aeplcdn.com//476x268//b...20151209201502
