ok so after some damage was taken to my Sinnis Apache 2015, I need to replace a single screw;
The screw lives on the handlebars, right hand side where the plastic square shaped mount is situated for the electric start button & killl switch, the screw hole faces downwards to the ground on the underside of this component and Is about 1cm wide if not a little larger and its a fairly deep hole at 5cm or so, this screw is missing from here and i am unsure as to what screw size goes in the hole!
Now I've just had a look online at CMPO.com and I believe this is the exact screw I need! anyone know for sure?
thanks
