PULSE ADRENALINE WONT START
I have just built a pulse adrenaline and I'm now at the point where the bike won't start, it tries to start when you bump it and compression comes from the exhaust with the electric start but no fuel is spitting threw, I am aware that oil is leaking from the left crank shaft which I have been told is oil seals behind the fly wheel, if anyone could please give any suggestions it would be appreciated, also if you think the oil leak could effect t it starting ?
Re: PULSE ADRENALINE WONT START
U answered ur own Q
No fuel = check carb jets & No debris in tank blocked fuel flow ...
oil seal is the most possible cause
Ref to shop (Suzuki/ Qinggi) manual as possible (I collected these in my computer [english]'05 GS150TD service data only /RV125 <VanVan>/ Qlink XF/XP200 | [Spainish]RV125|[Brazillan P...] EN125-2A / Sundown STX200 | Haynes manual gives u the general ideas ONLY ... | http://www.dansmc.com/mc_repaircourse.htm covers most topics u need to know
I have two carbs and checked jets they were fine, i think it may not be setup right, i will post pictures tomorrow to see if you can spot any mistakes ! i may have anserwd my own question but the bike isnt starting its as iif the cutoff switch is on when its not, theres just no fuel response what so ever
