Hi guys, have a strange fault on my XTRS. The throttle grip turns back too far. When closing the throttle, you can go past the closed position. This kinks the cable and eventually breaks the cable. I have replaced the cable, and adjusted it correctly, but the problem still occurs. Its like there should be a stop block in the switch body, but there is nothing. If you fit the throttle tube in the switch you can turn it round and round. Any thoughts?
