And for those who cant wait for the China lag Ive created this.
https://www.facebook.com/Df250rtB?ref=hl
If you already have a FB account if not now worries I still come back.
if you go through with it, be sure to let us know how it works out
i woulda high temp soldered it with a butain torch , but live n learn
I considered the soldering but I worry if heat rising or fl heat loosening the solder.
chruk bashre
scooterdepot. only $75 for a new tank.
that would be my first choice.
Crelow
Liked and added my page to the comments section.
4 Attachment(s)
My friend and I decided the first pair of logo's were a bit big here's the second attempt.
Attachment 11095Attachment 11096Attachment 11097Attachment 11098
After I saw the picture Bobthebobber sent with the chewed up tail light wiring I when out and checked mine. Since mine is the same model. I was relieved to see there was about 3/4" inch of clearence
chruk bashre
With my luck I go to put it on and make another leak. But I'll consider my options. Cycle world here locally has something used and similar for 75.
Went for a big ride yesterday , beautiful Autumn day. Ran fine for most of it, then went for a ride on the motorway ( Highway) where its also ran fine at 70mph but then slowing back down to normal driving it began to stutter bad under acceleration. Any ideas? Its got the bigger main jet, at 38 spocket. Havent messed with the needle though
Cheers Matt
Mixmaster
Cheers Matt
Pull the plug and clean or replace and check for color
and or pull carb and run a jet cleaning wire thru both jets. sounds like a tiny piece of something is clogging a jet orifice. The high RPM maybe knocked a particle loose.
start it , go wide open throttle and chop the kill switch and check your plug color , (better yet ride it untill its studdering and cut kill switch and check plug then)
and have a look at chain and air filter /choke
u using sparkplug that came with it ?
shuddering under acceleration makes me 1st think , leaking air intake manifold (the rubber bit that connects carb to the bike)
Can anyone who installed the 38t sprocket verify that you dont need to remove any chain links....and did the sprocket make much of a noticeable difference?
i put on a 35 and needed to remove no link , but will need to , its at maximum adjustment back now , if it stretches even a bit im having to pull 2 links
speed change went from 55 top rpm top gear to shifting from 4th at 70 indicated into 5th as on "overdrive" or cruise gear
I also use a 428 chain to let me get larger front sprocket (17 tooth) stock bobber it 520 chain that cannot do this
42-35 = 7 teeth , and 15 to 17 front , 3 teeth rear or 1 forward = 10% speed change so , about 43% speed boost just from my sprocket change = geared for 79 mph indicated max rpms , but remember we have pushrod motors so it makes more power 1/3-1/4 below max rpms , I think my powerband is set for 70-72 max hp in 5th gear
ps - I have seen this bike hit my indicated top speed of 80 , but conditions had to be perfect , without help it just purrs along at 70
6'5" 175lbs - flat texas highways
a 38 tooth no front change , your looking at perhaps 62-65 mph indicated top speed a 35 would add another 6 mph to that
freezerboy
To me its definitely worth doing, the gearing is way better. Not sitting at 30mph in top gear
Thanks Goodbar and Dan, yeah running factory plug. Will play around with all you suggestions and let you know how I get on
Thanks for all the input on the sprocket. I got a 38 i picked up from amazon a couple months ago that has a silver plating on which i am going to sandblast and paint black before i mount it. looking forward to this upgrade. Just hit 100 miles yesterday and the bikes running 100%. Got to change my oil now.
BTW, i ordered one of those electronic needle tachs from amazon and it arrived today. I plan to take the tank off in a week or two to repaint the bike and i will wire it up then. Ill keep ya all updated on how and if it works.
chruk bashre
i do not know exactly how your ride went, but..
depending on conditions, super revs, up alot of hills, warm air, one could float the valves. [if that's the case] just wait a day and it will run fine. sometimes hours. [and if you use]regular grade gas could cause vapor lock,flood the valves(float)and make a motor run like crap. top grade gas is better all around because the hotter spark lets you not have to work a bike as hard. less gas dumped in carb. runs smoother.
to keep up with traffic this bike has to be run hard enough to possibly cause a vapor lock.
like i say, i don't know what gas you use or how went the ride other than what you said.
hope that's all it is. cause that's an easy fix. and easy to avoid next time.
i know, sound like i floated a million valves. i have.
not really a million for all those college kids who are counting.
Thanks for the tips. I run it on 98 ron/octane so should be ok on that front
4 Attachment(s)
if you bought a sprocket from the no longer existing chinamoto on line store, toss it in the trash. safety hazard. i got one from old bike barn, its %ages better all the way. (38t)
going to hook the blue and white together and leave the green alone.
headlight blinding. tested it today.
Attachment 11219
found the airfilter i dream of, look wise. wont know how it all runs for a few weeks yet.
but here it is. and here is what it is. 2 in a package sucks. pricey. but nice place to store
the old one.
Attachment 11220
Attachment 11221
Attachment 11222
all wet sanded up for the clear coat on the fender and tank. so far all going good on that front. more parts n stuff coming in the mail. groovy. color me bobber,
chruk bashre
i dont see that cut blue/white wire in my wire groups. What color wires are next to that cut blue/white? looks like a yellow, brown and some white striped something.........can you see where the other end goes or ends up??
so both blue/white come from the front? I will remove my tank and have another look.
Thank you
freezerboy
This is sweet. Where do you connect the wires?
Bobthebobber
wires connect to:
ignition on 12v positive, ground, headlight on, and neg terminal of the coil.
dandaman- how did those sprocket bolts fit that you just got on page 326? did you have to cut them for length or do they fit right in?
