Re: Jialing JH600B Sidecar
I've got the exploded diagrams of parts for both versions if you'd like me to email them to you.
Great, thanks very much and of course the JL sidecar diagram is preferred via email and will look into good quality brand chains once back up North.
Emailed, but the zipped file is a hefty 13 meg. Let me know if you don't get it.
Emailed, but the zipped file is a hefty 13 meg. Let me know if you don't get it. Cheers!
Thanks! Got the file via email.
Now, can anyone confirm the JL seat height for the solo / sidecar, assuming they are the same and seats are identical as well...?!
I have used both Motul chain wax lube and Bel-Ray so far on all my bikes but spray cans get pretty messy sometimes.
Had a few Motul C5 Chain Paste 150ml/143g brought over from overseas and the chain paste is in a toothpaste like tube with a brush applicator. Uncap, unscrew the brush, remove a foil seal on the tube end, refit the brush, squeeze and "paint" it on. Seems to work really well. Easy to apply to both top and bottom of the chain and use the brush to work the lube onto the chain, fling resistant and no mess.
TexasAggie
Rox Risers
What type ROX RISERS did you use for your JL bike?
Did you change any cables as the bars sit higher?
Thanks for any feedback.
I used the same 2" risers as specified by Rox for a BMW R1200GSA. However, I have seen two separate handle bar diameter used on the Jialing JH600. Mine are the larger "pro-taper" syle but I think you have the smaller diameter straight bars on the side car. Just order the correct bar diameter. The 2" riser was somewhat limited as to how far back you can pull the bars due to the cables length. (at least on my 2010 bike) I like to stand on the pegs when I hit the rough stuff so I mainly wanted the bars higher for that reason. I only had to rotate the front brake line down and I have a perfect bar position for me. YMMV if you want the bars to come back towards you a lot.
I tried to upload some pictures but am being denied for some reason but if you go to my "First JH600 in Nanjing" you can see the pictures of my set up.
http://www.mychinamoto.com/forums/sh...+JH600+Nanjing
TexasAggie
thanks, collecting info for my ADV solo JL bike project and shall check into the handlebars later this month once I took delivery of the bike. did a search for your post about the ROX Risers on MCM but nothing came up, funny.....
Attachment 9804Attachment 9805
Site is acting weird today. Anyway, pics down loaded this time.
TexasAggie
However, I have seen two separate handle bar diameter used on the Jialing JH600. Mine are the larger "pro-taper" style but I think you have the smaller diameter straight bars on the side car.
Herewith confirmed, the handlebars are different on Jialing JH600 sidecars and solo bikes, the solo (2-wheel) bikes have variable dia. "Pro-Taper" style handlebars (silver) and the sidecars straight 22mm dia. handlebars (green)....
MotoKai
Cherry Red - Check...But after many kilometers in the mud I'd developed a kind of hardened cement-like plaque caked on....
spot on! almost new exhaust - used & abused exhaust.....
