i see you quoted me
but im not kev. :) haha
i see you quoted me
it's cool, he does have a pretty bitchin heist though. makes me jealous.
Took off the EPA crap off my Heist last night, went to work and had the model shop mill me a evap plate based off of the part I took off. I went to the hardware store and took a hole saw to the end of the exhaust and cut the baffle out. Swear the Heist is tuned for that configuration, runs so smooth now. Got it up to 60mph in stock form, would eventually get to 70mph. I was able to not only get up to 80mph consistently, buried the needle after the stuff I did! Really don't know how accurate it is, but damn! The results really surprised me! Loosened the stock seat a bit and it actually is really comfortable, may not need to do any springs or air bag. My uncle mentioned he knows a good pin striping guy and showed me some copper flake that he did on his son's bike, so I may end up doing that. The best $3,000 purchase I had ever made in my life, love the bike.
Hey everybody, been a member of the forum for a little while but haven't posted. I thought you guys might like to see a picture of my heist midway through the build. I had some machine work done to the aluminum trees and had the steering bolt extracted from the factory tree to use with the modified front end. Going to run some woodcraft clipons and probably raise the tank about 2 inches. I also have a bullet tail light and some mini led turn signals to install to. I will keep you updated with pictures as the build progresses.
Attachment 6969
Best motorcycle oil? Would you put this in your Heist?
Thats a loaded question, I use nothing but synthetic oil in my bikes, both the Heist and the Misfit use G&G Sheer power 10w30 for wet clutch application its tough to find but the Bel Ray or royal purple are also excellent oils. 1 Qt will do it
I found a really good synthetic oil will keep this bike running strong for almost 12000 miles
Its not the Heist but the motor is the same
http://www.youtube.com/watch?v=1_quivuGHcs
The two brands I read and saw good feedback were the Yamalube full synthetic and also the Amsoil full synthetic, I ended up grabbing two quarts of the Amsoil 10w40 and topped off the bike with it yesterday. It seems to run a lot smoother with the full synthetic. The local shops don't have the Bel Ray or Royal Purple, but I do have access to Amsoil pretty easily. I think I will stick with running that for now.
just make sure that it is for Wet clutch use
It is, it is. I went home at lunch to grab the bike, too nice here (66 degrees) to not be riding into work. It does shift so much nicer, still burying the needle on the highway. I need to put my GPS on my tank and see if I am actually going that fast!!
