5 Attachment(s)
Re: Jialing JH-150GY-3 impressions
now that I've got my tools stored in the panniers it's time to repurpose the original tool box
Attachment 11214
skateboard hardware + recycled grommets from the JH rear rack + tool box mount
Attachment 11215
Attachment 11216
Attachment 11217
Attachment 11218
hope you guys don't mind me bugging you with these minor updates ;)
... how about exposure to dust and dirt?
ShuBen
you can't see it too clearly in my photos but the pump has a T-Handle that flips out - so that protects the "Shaft" from getting grime in there. The handle also has a slot that the nozzle snaps into to prevent from getting dirt in there too.
Attachment 11232
Barry
here they are a little cheaper: http://item.taobao.com/item.htm?spm=..._u=lueorntc1db
went to clean my air filter (what a pain! who designed this thing?) and I noticed the connector on the exhaust didn't seem to be sealed properly - plus a lot of carbon blown back up on the engine top-end, weird right? I figured I'd re-seal it after I cleaned the filter.
Attachment 11392
then I discovered this problem (which I'm guessing caused the first). one of the exhaust mount brackets is gone from the frame! seems like it rusted and snapped. but where'd the bolt go too?? Whatever - this probably introduced extra tension on the exhaust joint and caused the blow-out. Now I need a piece of scrap metal to weld back on their and properly mount the exhaust.
Attachment 11393
also, anyone know the valve spec? I'm about 400km overdue for an adjustment and the bike definitely needs it.
thedannywahl
CRF150F (63.5 x 49.5) is 0.1mm +/- 0.02mm.
thedannywahl
that sound like some overkill. Were you having serious issues or he just didn't know how to work on carbs? :P
How about some pictures and how does it run now?
I decided not to change it, I was writing about motorfans case
Happy birthday JiaLing in Gansu!
Attachment 11669
4 Attachment(s)
Hi!!
This is my china moto
JIALING 150 GY3
Guerrero GXL 150 ARGENTINA!
Saludos desde Argentina!!!
Attachment 11709Attachment 11710Attachment 11711Attachment 11712
5 Attachment(s)
