I found something interesting which leads me to perhaps conciser we may have a universal CDI wired as DC
http://www.atvsnetweb.net/asset/edge...vp/acdccdi.jpg
but this one says something different:
http://www.kazumaracing.com/images/i...-6pinSPECS.jpg
Our CDI is using a 5 wire hookup so... what can i say
Im going to stop commenting here until i rip apart the wiring and figure out exactly what the deal is.
http://atvconnection.com/forums/chin...o-spark-2.html
Barnone, AXa ,,, I have just got a problem agin hope you guys can help with,,, just had the bike pass the registration test went to ride it to the MOT center to finalise all documentation and lost Left side indicators ???? checked lamps and then basic wiring plugs etc,,, all seem sound right was working now lost all indicator's...... can you pass any wiring drawings for these bikes or parts list for a new flasher box ?? were can I order etc ??? or even if I have missed looking for something ,,,, all your help is much appreciated... don't forget mines the 125 RTB if that makes any difference.
booi10,
Probably not much help but a parts lists for the DF250RTB is at http://www.df-motor.com/MLC/Parts%20...0RTB(2014).pdf
#5 on Page 21 is the flasher.
Well I guess that CCW could not call it a 250cc big bore kit since they use to claim that the stock engine is 250cc.
These guys are still advertising "Change your CG250 67mm air cooled engine (167FMM)to 70mm bore,Kit include piston kit and gasket".
http://www.chinese-parts-canada.com/4_stroke_big_bore_kits.html
I never have gotten an answer from them.
Anyway, I'm happy with my DFs performance for now.
Maybe DF will put the overhead cam engine in the Df250RTB's next generation.
Generally, when a "big bore" kit is installed,the crankcase has to be bored larger to fit the increased diameter of the new cylinder/jugs.
(on a Yamaha 250/249cc ,it can be increased to 334cc- $599.95 and one owner said it made a BIG difference in grunt).
personally, I just use a bigger bike,if I need that much more power...
The wiseco piston and rings are US made.The piston pin boss is machined a tad bit lower than stock which allows the piston to rise further up in the bore,more compression.It's one of the tricks they used and I figured it out after installing quite a few in my bikes over the years.I had to raise the cylinder block on my GS 569 project by shimming to keep pistons from hitting the valves.They didn't know I was using Megacycle high lift long duration cams in my build.I bought them before the cams.
axa,
Sounds good. Is 68 indicated GPS or speedometer? True speed?
