998S
Frankly that sounds very much as a TIC solution, not knowing the problem, and just starting to change parts, hoping sooner or later the problem will be fixed.
I suspect that the JH-manufacturer got it wrong on the exhaust gas regulations it has to fulfill for the Chinese approval, then set the injection too lean.
PS. An idle speed of 1700 is FAR to high for a 2 cylinder.
Even a high compression Ducati 2 cylinder runs perfectly at 1100-1200 rpm idle, and my Chang Jiang with a large flywheel ticks over at 800 rpm ....
