Thanks mo. She is running just fine with no issues. Knock on wood!
Ordered a set of tires for her, bought both off amazon, different sellers.
Shinko 777 Series Tire - Front - 90/90-21
Kenda Cruiser K671 Motorcycle Street Tire - 140/70H-18
Read the reviews on them, they seem good especially for wet weather, which i always seem to be caught in around here... being Texas and all. Got the rear last week, just waiting on the front. Then i will put the bike on a jack, remove the wheels, and get the tires put on. I guess I need to look for a place to do that. Not sure, but maybe any local motorcycle dealer may do it Like a Honda dealer. But I will call just to make sure.
Original tires worn out? Mine show almost no wear but I only have 3800 miles on them.
You should consider changing the tires by yourself. It can be a wrestle unless you do it right. If you have no clue how to do it, then consider watching some youtube videos, and prepare to wrestle.
Yep, they are tubeless so that makes it easier.
slight wear on the rear, not much on the front. 16,000 miles on them.But they have some cracking and oldness looking to them. Figured it would not hurt to change them out.
I will take the recommendation to check out you tube videos, and possibly do it myself. couldn't hurt. Just concerned with the balancing of them.
I don't see the need to balance the tires due to the low speeds of the DF. I'd try them without balancing them. I don't remember seeing any balance weights on the wheels, I'm in VA for a week so can't take a look at my DF.
That is a fair point. I do not see any on the bike at all. Funny thing is that sometimes when I ride, I give the front wheel a gander from above the handle bars, and it looks like it wobbles? I think that is attributed to the spokes. So maybe I may need to check the spokes out and make sure they are all good and snug (not over) and maybe that will stop the wobble. The wobble does not make the bike shake at all, so I never really had an issue with it, it just looks weird.
If you mess with the spokes... you might break the air seal and have to put a tube in to hold air.
Yep, if it ain't broke don't fix it.
Not sure how the spokes are sealed and don't wanna find out.
Put the new tires on it and then see if you still have wobble. Could be the tire.
good points again, glad I come here. Lessons learned. Just put the tires on, leave it be, works for me.
There is always using stick on weights.I static balance all of my wheels.I have never had an issue with vibrations from balance.I rarely break 90mph on any of my bikes.I'm not a speed junky.Plenty of utube vids on static balancing.
My DF loaded to take to FL for the winter.
http://www.mychinamoto.com/forums/at...id=17831&stc=1
Where have all the DF owners gone?
Hey all, Hope everyone had a grand Holiday. Everything here is awesome. Tires working out great, not really broke in yet, haven't run into any rain yet either..thankfully... been getting cold.
Just passed the 17,000 mile mark as well. Still going strong. Was wondering what happened to Scooter Depot? Friend is looking for an inexpensive four wheeler, checked to see what they had.. they are gone? Any one have an alternate place?
17 k miles! WOW. I only have 4k on my 2012.
http://www.mychinamoto.com/forums/at...id=18132&stc=1
Still running just fine.
:thumbsup:
bowtiewagon,
My ignition switch is acting up like making contact and then losing contact. I can wiggle the key and it loses contact. Didn't you have a problem with yours? If so where did you find a replacement?
Thanks.
Spray some contact cleaner if just moisture / dirty...
btw Ign s/w cames in different grade
http://item.taobao.com/item.htm?id=44976748768 (Google Chorme auto-translate...)
https://img.alicdn.com/imgextra/i3/3...-389662530.png
humanbeing,
Thanks for the link and tips. I'll try some contact cleaner. I need to look at the wiring diagram to see what type switch I need.
Barnone, sorry I did not have an issue like that. Hope you can figure something out. And post a remedy here. Always good for more info.
Just for fun, up to 17588 miles on my bike at this time this morning.New tires rock, had to replace the tail light, old and cracked one before. Found actual duplicate for around $12 from china. simple fix.
bow,
Senior moment on my part. I'll try humanbeing's contact cleaner idea first.
Contact cleaner didn't help and I didn't trust the ignition switch since it would go off and on if you wiggled the key so I ordered a four wire ignition from Amazon.http://www.amazon.com/gp/product/B00U7AUWME?
psc=1&redirect=true&ref_=oh_aui_detailpage_o01_s00
Couldn't find one with the same connector as the old switch so just cut the connectors and spliced the old one on the new switch. Made bracket out of some aluminum and bolted it up. Cranked right up and went for a ride.
http://www.mychinamoto.com/forums/at...id=18240&stc=1http://www.mychinamoto.com/forums/at...id=18241&stc=1
Your pics aren't showing up.
I don't know what is going on with my photos. I could see them just fine.
http://www.mychinamoto.com/forums/at...id=18242&stc=1http://www.mychinamoto.com/forums/at...id=18243&stc=1http://www.mychinamoto.com/forums/at...id=18244&stc=1
I can see them in your last post.I don't know if it's the forum, my computer, or my browser.
