gpPeej
Wow...you are wearing a hi-vis vest and that is still happening??? I wear a hi-vis yellow helmet and it helps some, but this happens to all of us.
Two things that I do to improve my chances of being seen are both based on the fact that most people key on movement and moving things in traffic. To that end, I loosen up the bolts that hold my headlight so that it vibrates more than normal. It's a little annoying at night but it sure gets noticed more during the day. Also, when I have an oncoming turner or suspect someone entering from the side, I "waggle" the bars slightly to give them some movement to key on.
Still, you'd be wise to practice panic stops. Also, alot of US scooterist and motorcyclist have been adding Stebel air horns to their rides. They're cheap, compact, and put out 130Db. But, you can't rely on a horn unless you see the problem coming. The pipe on my Lambretta is louder than it's horn.
Perhaps you should get one of those really bright yellow police jackets and wear a white helmet...not many folks will pull out in front of a "cop". Have you ever seen the hi-vis riding gear made by Aerostitch? Great stuff
Peej
