Re: Qingqi QM250GY-B ride review
andres357mag
RotorTrash
I want to put LED turn signals to my 200GY. The LED turn signals has the same wire terminals. Is the Flasher Unit also the same? I mean Same Wire Terminals? Or maybe are equal in volt and amps specification so I only need to buy the Turnsignals.
The LED have a built in resistor, they use less then 12v, the bank of lights are set to the resistor. They would connect to the same terminal the voltage is reduced within the LED assembly, ie the resistor.
andres357mag
... buy the Turnsignals...
Change to a led friendly "Unit" (some can works even at ~0.1w) + cheap LED bulb is the esaiest solution
