Re: hello everybody, can anybody please help me?
d.j.jake1/2,
So where does your problem stand?
still the same sir. got no time to fix my bike becouse theres no time. maybe this sunday. and heres my new promblem sir. when i ride at night and i open the front lights it doesnt light in the mid mode, but when i push the button high the lights then is ok.
d.j.jake1/2
I have both same problems on my China bike:
Front brake is squeaking all times, applying slight pressure on brakes stops it, but it starts back as soon as i release the brake lever.
Once I left by disk lock on while I started the bike, the wheel turned once and got stuck, was a pain to unlock the disk lock after that but it stopped the noise for a couple thousand kms, now it's starting again...
Cheap parts are cheap for a reason, so I'll just change it altogether before to have a bigger pb than that annoying noise.
For the headlight: It obviously is an electric pb, changed the bulb 3 times, and after only a few hours of use; same thing again, Regular-beam is burnt, only High-beam remains, don't ask me why.
Asked the mechanic who checked the battery's output while revving the engine, nothing wrong here so he couldn't fix it...
I suppose it delivers too much power to the reg beam so it fries the filament, I thought of adding a resistor on that specific wire but found a simpler solution:
I drive either on Low-beam so to be seen, either High-beam so I can see.
I lowered the head's angle and I "blacked-out" the head light in a T-shape with black tape so the High-beam don't get me every other user's High-beam in the face.
One could cover just the top half of the head light but the bottom half still is killer, adding the bottom corners to complete the T-shaped mask really helps lower the intensity into smthg like the Regular-beam.
Then u only lose the High-beam, no big deal for me who don't exit the city...
I know it's no real fix, but it solves the problems...
Driving a cheap China bike has cons, u can fight them forever, or play it the China way.
If u need the High-beam cause u drive out of the city a lot, then I'd suggest adding a light 12V resistor on the Reg-beam wire, easy fix without knowing nothing about electrics, if it still fries it, buy a new bulb & try a bigger resistor, till it works.
Good luck.
yes sir youre right sir. the regular light is broken and the bright only remained. i changed now with the same stock light. i bought a pair 2 weeks ago and its ok. 18w bulb.
hahaha i love the last quote sir.
yes having a china bike, you must need to be very techie or else save money for mechanic.
