@acif
Than you so much for Suzuki bearing dimensions:bowdown:
I found used front 21" wheel from suzuki DR 125 for about 60USD (without brake disc), i will buy it in next few weeks..
Cheers
Progress:naughty:
Parts to fit the Suzuki dr 125 21" front wheel on Qingqi QM200SM:
1. 2x bearings 15x32x9mm
2. Resize spacer between front wheel beraings from 12,2mm to 15,2mm
3.Optional (Change QM200 speedo drive with DR125 speedo for accuracy)
P.S Qinqgi speedo drive can be used only as spacer, without speedometer function!
nice job there looks very decent, have you managed to find a rear wheel yet?
Kennon
tnx Kennon!
Qingqi dealer in my contry sales dualsport bike only with drum brake on 18" rear wheel, i have motard with 17" disc brake..
If someone know motorcycle that have same or similar 18" rear wheel I am open to suggestion..
For now, i think that Suzuki TS125 rear wheel would be low-cost solution..
have you thought about threading a 18'' rim to the standard hub?
ahh i see not a bad idea having a dual setup
iv seen on the official website they have updated the dual sport model with rear disc brake setup
http://www.qingqi.com.cn/en/product_show.aspx?id=89
im not sure on its availability, but will probably cost more than a TS125 Rear wheel
I have been planning to somehow raise the rear end, or just adjust the rear shock, but i dont know how, some proposal?
For now I have sketches of HLS for Suzuki DR125,but I'm not sure if the dimensions of the rear shock absorber on Suzuki DR125 are the same with Qingqi..
measure yor shock from eyelet to eyelet.there are various sizes of shocks for the dr125 and dr200.
