the local locksmiths had a blank in stock that looked similar enough to work. But is wouldn't fit into the ADLO lock.
When a new key blank didn't show up immediatly, I took the lock apart. (and managed to get it back together correctly after some of the tumblers fell out. I believe I could have gotten one of the ilco blanks cut and then ground thinner on a surface grinder.
Next project is to get two JCWHITNEY cases and the ADLO case keyed alike.
I may see if I can grind out the flutes and then use a reduced number of tumblers to get all three to match.
Onward and upward
Tom
