Re: Qingqi QM200GY-BA battery area wiring
forchetto
The item you mention that is held by a chassis tab is the winker relay. There's a bunch of wires with a connector further up, but is well protected from water thrown by the wheel.
The thing to check is the tightness of starter relay connection posts and specially the main engine earth cable. This cable is responsible for all current out of the generator and all current into the starter motor. Any resistance there will make things funny.
The following pictures show this cable, at the chassis end and at the engine end. The main battery earth cable also has to be tight.
http://www.telecable.es/personales/a...atteryarea.jpg
http://www.telecable.es/personales/a...ngineearth.jpg
Hi forchetto... i need your help, maybe you can help me to solve my problem. The problem is when the battery weak or damage, i cannot start my engine using the lever kick start like in the picture below. So what you think? Anybody also can help is they know how to solve this problem.Thank you!!!
Attachment 7751
Hi Hescort and welcome to MCM!
My best bet would be to check the rectifier/regulator. That might be burnt and might need a replacement. If the R/R works ok, your battery'll get charger and you'll forget about kickstarting your bike.
Qingqi's motor should start regardless of the state of battery. Just kick start it properly or simply try to push start him in second gear.
Re: Electrical Probs with QingQi 200...
http://www.triumphrat.net/members/44601-forchetto.html
if you looking for him....
Based on the information I would guess maybe a dead battery and flooded carburetor? Can you ever kick start the bike or do you only attempt to kick start it after multiple failed attempts with the electric ignition? Is the ignition clicking or is it going rrrrr? The first is a dead battery the later is fuel not enough or too much of it.
My bike is very difficult to kickstart when the battery is dead and will flood easily, when my battry is good, it kickstarts with ease. In reference to my original post at the top of this thread, I replaced the battery with a new one and the problem was solved. (The original battery went deffective after a few months.)
In response to Hescort's post, I have been kickstarting my bike recently with the battery pretty much dead. The lights come on when I turn on the ignition but are dim, and the electric starter will not turn over at all, the solinoid wont even click. A few days ago I kickstarted it and it began to sputter when I reved the engine, it went away after it warmed up. The next day it began to sputter when riding to work. So, I recognized these symtoms when I had the problem with the original battery. I replaced the battery yesterday with a new one, and problem solved. For whatever reason, the bike will not kickstart properly or run properly when the battery is dead.
