Re: dong fang d250rtc engine sprocket and chain mods
jaydre727
Hey so watt wattage r ur headlamps
The bulbs in mine are 25/25W. The brights do suck. I thought about getting the HID kit from eBay, but I don't know how hot they run, and if it would really help.
DanDaMan
http://www.rebelgears.com/pricelist.html
u will need measurements , opening size , bolt size , bolt distance , ect
but they will custom make it to your specs and mail it to ya for about 55 bucks
if you call them they may already have the bike on file
I was pointed to Sidewinder Sprockets by another user recently. They make custom sprockets from many materials. I think I will check them out as well. I am trying to avoid aluminum if possible. Thanks. http://sidewindersprockets.com/custom.html
DanDaMan
35 tooth perfect from what ive heard unless your really light then could go to a 33
I installed a 111 main , runs good but think needed to change needle jet as well
as for the leak you sure its not just the drain plug leaking back ? auto parts stores sell oil drain bolt washers to stop the annoying drip thats common from pan drain bolts
Where were you able to purchase the correct jets for this carb. I wasn't able to find exact replacements, but have been told that it is a clone of a Keihin PZ30. I used a precision drill bit to upsize mine a little bit after I installed a performance air filter and opened the exhaust. I over did it a tad, so now I will have to purchase at least one more main jet.
Thanks.
