I now have electrics running but no power at the push button start, suspect a dodgy starter motor will check it when I get the time now, the person I bought it off didnt reconnect the live wire for the main fuse to the battery
It wouldn't hurt to get your self a multimeter so that you can go over the electrical system and see where the problem is. It does however sound like your starter motor won't turn over because the kill switch is on or some safety circuit is engaged which would be caused by the side stand being down or the bike being in gear with the clutch out, I think I have read somewhere that the side stand switch can fail quite often on Pulse Adrenalines.
