what I found was the gear shift lever was set far too high, so had to take my foot off the peg, lift it up to change down, and when changing up sometimes had problem with engaging 2nd /3rd... Don't know if this is the same problem... What I did was remove the 8mm bolt pull the gear shift lever off splined shaft... Move it down a few splines on the shaft so it was in a more natural position... Re-fit bolt... All good now no more problems.
Yes it is the same ???? will try re-fitting the gear shift and see if it helps me but i have found and other rider who had a go its only at low RPM . the 2nd/3rd sometimes dont go in we did try it at a bit higher RPM and it went in fine but cant try much about 5k still running in but thanks for your point of veiw as to the low fuel warning light .. It dont have one lol TIC but i can tell you you should get over 200 miles from a tank . On my first tank done 310km used 14 L of fuel so from a full tank you should get 380km but work safe on 350km
