Review at 7000 kms (+10,000 with friends 2008 model=17,000 kms)
The bike never fails to run, but it can be question sometimes of how it decides to run! The weather conditions effect the engine, wet, cold and hot make it run poorly, sometimes the bike seems fuel-starved, other times fuel-rich.
The bike is based on a Honda CMX250 which is a cruiser, in terms of its swing-arm, wheelbase and tire-size, which means the wheelbase is really a cruiser distance not that of a naked road bike, this seems to make the handle more cruiser-like than maybe it could be. The pegs are big and are out a fairly long way, so knee-down stuff is trickier than on a YBR or CBF150. You are also sitting in the middle of the thing which is stable, but the bike can't wheelie at all as the rear wheel is too far back.
Think maybe like this , but obviously much less extreme!
http://assets1.indy.com/photos/25819/default.jpg
The gearbox works well, other than it has a tendency to jump back from 2nd into neutral, when changing from first, both bikes we have have this tendency, unless very firmly changed from 1st to 2nd. The exhaust and speedo are junk, there also seems to be some power restrictions in the exhaust system, such as a double-lined header with a third restrictive steel sleeve. The baffle which is centrally located is prone to being bashed and has some other silly restrictive things in there (probably for emissions) and there is no way for condensed water to get out of the system. The clamps and places where the exhaust bolt to the frame are poorly welded and seem prone to snapping, we have snapped 5 between us on two bikes.
Also the warranty lasts a year, or 6000 kms,. So I have to pay for everything from now on, and I only bought it in late August 2009!
In the long term I'm not that worried, I bought the bike knowing it wasn't perfect and have improved it so far by dampening down everywhere I can with pieces of rubber, and changing the brake pads, which has made it stop quicker and less vibratory. Now the bike is out of warranty I will change the exhaust system, to make it less restrictive and run it all the way back in a solid piece with aftermarket mufflers at the rear. Put a K&N type air filter on. Change the rear shocks if I can find some the right length. Maybe stock CB400 may be OK. Change the leads to NGK, rev and speedo and possibly carb and or jets. In the longer term even the swing-arm and the engine to Jialing. Spending 2000-3000 to make it more like a nighthawk isn't a worry.
I've heard unconfirmed reports that RR want 13,000 for this bike in 2010, but unless its been massively improved it certainly isn't worth more than 10,000, and with reports that the Yamaha YBR250 has this year dropped to 23000 RMB, and maybe even 20,000 is possible, this might be a better and more reliable choice for a 250 in China.
I would only recommend the RR if:
1. You are really desperate to have a twin, not a single.
2. You realize it has flaws, and will try to spend money to upgrade the bike/fix whatever goes wrong.
Fully assess your options before buying this bike, it's by no means terrible, but there may be better out there, but it's gonna be hard to tell with test rides being so rare in China, and the fact the few riders are properly objective about the strengths and weaknesses of their machine.
