cone air filter for the motard?
thanks carl for the pipe thread,mabe i'll try that.but another thing i want to know if its possible to replace the stock air filter with a cone air filter? a friend put one on his monsoon scooter and it performed mutch better than it did before, i geuss its because the bikes breathes better. so any suggestions or tips would be apreciated on this. And thanks for the sweet site i allready reffered it some of my friends,keep up the good work
Re: Qingqi QM200GY-BA Super Motard
I live in Honduras and recently purchased a KMF ZX200. I was tried to research it before I got it but never found any info. until now. It was great to read but it looks like the last posts were in 2008. So far it seems fine for getting around in town. Not a lot of power but have got a lot further to go before it's broken in. Maybe then it will feel stronger. I saw where someone posted they just finished a 5000K trip. I was concerned about maybe going a couple hundred miles on mine. With the mountains here I'm not sure I'd try it. Here the asking price is over $1,800. I was able to negotiate a better price, but under the Genesis brand it can be had for about $1,050. I wish I had found this Forum before I purchased. I' love to hear from other riders. Email if you are near Tegu.
Re: Qingqi QM200GY-BA spokes and sprocket bolts.
Hi,
Does anyone know what oil filter I need for a Qingqi QM125 and where it is on the bike? Im in Spain so any local references would be great.
Thanks in advance.
SpanishFlame
Hi,
Thanks in advance.
This may help if you follow the thread!
http://www.mychinamoto.com/forums/sh...PDF-%282008%29
SpanishFlame
Hi,
Thanks in advance.
Suzuki Geniune parts # 16510-05240 OR compatible from other brands: Hiflo HF131
MotoDrunken
Hi! I am new to the forum. I live in Honduras and recently bought a 200 SuperMotard made by Qingqi. Here in Honduras there are two importers, The biggest one is also the official importer of YAMAHA; the other one is a small importer who also runs a Moto Shop. This bike is named here Genesis SuperMoto and KMF by its respective importers, and differs only in color and decoration between them. I have only ridden it (The Genesis one) to the extent of 300 km by far, and am really pleased with it. The only problem I had is probably my fault: I was in the process of changing the original handlebar (which I advise, in terms of getting more strength from a reputable aftermarket firm) when I noticed that the little pin of the switch in the left lever bracket (clutch lever) was missing, so, that device that prevents you from starting it in gear without disengaging the clutch is rendered useless. I should have checked that in the sales room prior to choosing that particular bike, due the fact that the electrical componentes have no warranty. But, so far, I do not feel hindered by it because I hope I will never attempt to start it in gear. I have read mostly good reports in some forums about it, but also some horror stories about broken third gear, broken sprocket screws and loose spokes. Any of you have any experience about those subjects? A very good mechanic of my aquaintance also told me that some times that things happen, in his own experience. Sorry for a message so long in my first attempt. A friendly salute to you all. Keep the wheel side up!::thumbsup:
IN HONDURAS:
I just took my KMY ZX200 in for the 1,500 km checkup on tuesday. I noticed some spokes loose on the rear wheel and asked them to check them. On Friday I was riding and had a blowout on the rear wheel at speed. It was a little nerve racking but got it stopped okay. One of the spokes had come loose and went down into the rim, bursting the tube, The end of the spoke that attaches to the hub was the only piece (approx. 1 inch) that was not down inside the rim. Since rims and tubes are not under warranty, I expect I will have to pay for this. Does not seen right to me, but am glad to be alive!
rmortonjr
Glad you're alive and this didn't cause bigger problems for you. One thing you will read over and over on this site is the spoke issue and how it can destroy your rim, cause flats, and eventually make your sprocket fall off. Take a little time and check all the sprocket bolts and spokes on a regular basis. Remember that tightening a spoke is opposite of what you think. Usually if the spoke is loose, you need to tighten the spoke on the other side of the rim to make the loose one tighten correctly. Search the web for "how to lace a spoke wheel" to see the correct way.
Just purchased a Qingqi (Konker SM200 in Canada), motard. The front wheel is 17"x2.5". I was thinking of putting on a 3.00x17 Shinko 244 tire. Any thoughts on the wheel being too wide for this particular tire?
