Now that's some good weekend reading!
Wonder why I never checked their US site in the first p[lace. Stupid of me.
Man, thanks a lot!!!
If it is TPS indeed, I guess I'd rather change the sensor before it screws up completely.
you're welcome! I'll do few changes in the near future (painting, brake/clutch levers, pegs), will keep you guys in touch.
Painting mods like mods or like completely repainting the bike?
Nop, just the 2 carbons pieces on each side, here's the result on the standard bike:
Attachment 9207
And it looks good!!!
Oy mates, I'm looking to change both of my levers (brakes and clutch) on my 650nk: could someone advise me a lever's brand that would fit my nk? I could tobao it.
probably will have some for them soon, the levers on my honda are a non descript chinese made CNC items which work really well.
Kennon
Could someone advise me a shop in Shanghai whith a good amount of accessories for motorbikes? I'm looking for levers (clutch and brake) and a new horn for my 650NK. I heard there's a good one in Gubei area but not sure about the exact location though...
Here's the kind of clutch I'm looking for:
http://item.taobao.com/item.htm?spm=...id=18685251842
If you can advise me a reliable horn system: I'm all hears.
These are very loud but quite big and heavy, can be difficult to find a good place to install it. (chinese copy of the Nautilus exhaust)
http://item.taobao.com/item.htm?spm=...&id=3179692131
These are more discreet but can be very loud if you wire them up properly with a relay to draw power straight from the battery.
http://item.taobao.com/item.htm?spm=...id=12610507306
For choice of bike parts taobao is probably better than any shop you'll find in shanghai.
Had and still have a few genuine STEBEL NAUTILUS horns and they can be split to mount easier and save some weight, good solid very loud horns....
How to split the horn: http://www.motorcycleinfo.co.uk/inde...pageId=2173985
Thanks for your feedback mates, any idea of which clutch could fit my 650NK?
could you get a take your lever off for a picture?
Kennon
You might be interested in these on taobao ... they look nice, but I cannot advise as to the functionality of the levers.
Attachment 11297
1. Taobao dealer with several levers for the 650nk 元198
Attachment 11300
2. Taobao dealer with several levers for the 650nk 元299
Attachment 11301
3. Taobao dealer with levers for the 650nk 元169.90
4. Taobao dealer with levers for the 650nk 元158
Attachment 11302
Thank you for our insight bikerdoc, I might buy the 299rmb one you're advising and see wheter they fit. I will tell you guys if they're functionnal.
Kennon, here the pictures of the clutch lever of my 650 NKAttachment 11322
By the way I bought the horns felix advised:
They're loud, discreet and efficient: I clearly recommend them.
T.
the levers bikerdoc posted look right for the fitment, I had abit of trouble fitting mine to my honda with the clutch cable forgot to loosen it up but work allot better now. The first two links have adjustible length I wouldn't go for those as they are quite flmsey better of going for the soild stubby to full length ones my bike originally had too heavy a clutch so changing the lever to a long adjustible made it allot better on city rides.
Kennon
Guys,
thanks again for your advices, I successfully installed the levers Bikerdoc recommended, they are fitting perfectly, good grip, material seems solid, here is the result with the new levers:
Attachment 11367
Hi Guys, any ideas of which handle grips might fit the bike? The standard one are unesthetic and not durable (the rub is already wearing off).
Hey Guys,
I was thinking about replacing my grips (the rubber is wearing off) with the Scott's one.
Any idea if it'll fit? Here's the link:
http://item.taobao.com/item.htm?spm=...id=15837174753
Attachment 11637
It is very likely that, if you buy the proper diameter grips (I guess that is 7/8 inches on your bike, so, in metric, left shoul be 22 mm, and right, throttle grip, some 25 mm), you'll be able to install them. However, you should pay attention and order grips open at both ends or to modify these colorful, with closed end.
Thank u for ur quick reply Zorge, I was planning to simply cut the edge. I'm just afraid it might not fit as it's supposed to be for dirt bikes.
Well, this is no big science. Handlebar diameters may vary from 7/8, 1, to 1 1/4 inches, or even thicker (but their ends are reduced to forementioned masures), but I don't think that CF Motor would experiment with non/standard sizes.
By my experience, the biggest problem may be, not installing new, but removal of the old grips, especially the plastic insert from the throttle grip. But I think that dipping in hot water and spray lubricant will help.
The old ones: just cut loose.
By far the best way to install new ones (after experimenting with every other alternative like soap, hairspray, water, tape, etc) is compressed air.
Have a nozzle with a small exit, and just blow between the grip and the bar, while you slowly push the grip.
It blows up like a blowfish, and as long as you keep the pressure on it, you can position it exactly, even take off again.
No mess with liquids, and tight immediately.
Works like a charm as long as diameters suit.
Cheers for this grandma recipe man ;)
Hi, which kind of handlebars did u buy?
Handlebar grips: Scott for dirt bike, very thick, but not fully satisfied honestly:
Attachment 13174
Still looking for esthetic/efficient one, guys any advice???
I installed one only, the High one, keep the other one in case.
Here's mine and it's reliable:
yes, havent seen that model here (its black so i might have over look it )
but have seen these here
http://en.seger.com/product/50f/
http://en.seger.com/product/45c/
will go market today look those horns. louder the better :thumbsup:
