Re: CFMoto 650NK/TR parts numbers and maintenance guide
choldy
any chance of re posting the correct page link to the service manual GRB?
Service manual?? that link is still working.
http://www.mojomotorcycles.com.au/su...e%20Manual.pdf
EDIT: First try it worked, second time it told me that "Sorry, we were not able to find the page you that you requested. "
so something wrong
but it does work.. this loaded fine..
Here is dropbox link!
https://www.dropbox.com/sh/vqsrkcaqv...e%20Manual.pdf
You can use Toyota 90915-YZZE1 or 90915-10001 Oil-filters. (Toyota, Camry 2002-2006)
Attachment 15414
Guys...greetings from Malaysia. im newbie here..need help from u guys. Its regarding my CFMOTO 650NK..1st edition. Its developed a hiccup at idle and high speed. Ive changed everything..from ecu, throttle body, wiring set, spark cap, rectifier..etc..but i still cannot overcome this issue. Wondering if anyone out there willing to share any experience, perhaps on how to fix this?:confused1::confused1:
Can you be more explicit? What is a "hiccup"? Can you upload some video?
Wald0
Thanks for the link. Any possible link for the 650 TR/TK?
ZMC888
240kpa is in pascals. This pressure is the same as 40psi, that only applies to the Cheng Shin OEM tires when fully loaded. Regular tires are probably 36 rear - 32 front.
Prince, you went on Taobao and typed in 650NK? Thanks but I already did that. Thing is with Taobao, if it isn't made in China or Taiwan it's actually more expensive than the west and likely fake. So if you want made in Japan/UK/USA brake pads etc it's actually better to buy from overseas and have them sent, but you need the part number as there are like 30 or more regular sizes. Some things they hardly ever fake (tires -too hard) and other things they often do eg engine oil and handlebars, reason=easy.
Was wondering on this question myself. So what's the best setting for TR/TK? Thinking 280kPa a bit too high.
DavidC
Generally most people suggest 36psi front and 38psi rear for most normal modern street motorcycles.
ZMC888
Thanks. I will give it a try and see how it goes. Hope it will be sufficient to handle the panniers too.
Sorry to bring back an old thread, but have we confirmed that we can use FA192 from EBC for the rear brakes? Mine are about done at 1400 miles :( 2014 650nk
Yes, you can use FA192 EBC pads for rear brakes in the 650NK. The original rear pads last about 12.000 miles in my 650 NK
My CFMoto 650 TK/TR clutch seems to be showing signs of slipping. Any ideas what is the correct parts to get and how long does the clutch lasts? Mine just passed the 36k km mark.
DavidC
... Any ideas what is the correct parts to get ...
Folks selling compatible fraction plates said:
for Kawasaki: ZRX1100/1200 , Zephyr 400/1100, Vulcan 800/900 | CFmoto: 650NK/TR
The best sale in taobao is https://item.taobao.com/item.htm?id=38852290900 [8 fraction/ 7 metal] ¥570.00
Genuine parts should be as https://item.taobao.com/item.htm?id=521609383953
Hi David
How long should a clutch last?
That would depend on how you ride if you ride solo or 2 up?
By I would expect to see well over 70.000 km that is based on the km on my last bike (TR-G) same engine as yours which had done over 75.000 km.
Sometime if you need to make your job a lot easy. then some people buy and fit a complete clutch assembly.
link....... https://item.taobao.com/item.htm?spm...A%22item%22%7D
Cost in China under 1300 RMB.
Hi all,
Does any know of a replacement swingarm bearing kit? I can't find anything after extensive searching.
