haha not related but http://news.yahoo.com/motorcyclist-c...113500876.html yikes
Guess I should of known it would happen after reading the posts on here. I opened up my garage door and smelled yes you guessed it. Gas tank leaking. I'm not even going to try to repair the leak. Going to start looking for an alternative tank.
what size drain plug should i buy? 12mm for honda ruckus?
Go here.
http://www.ebay.com/itm/390427481274
thats the exact one i was wondering about. thanks
I use this this magnetic oil drain plug, 12mm x 1.50, $9.32
http://www.oldbikebarn.com/BikeMaste...AG-12MM-ALU-BM
So i called scooter depot and they are sending me a new wheel or tube or something and a new speedo. i did some painting, installed a 115 main jet (my stock one was a 105), shimmed the needle with one washer and relocated the airfilter out into the air strea, installed a new ngk plug now its running tip top. The more i ride the more i like it. Definatly the next step is a new rear sprocket but before i order one i need to know if anyone can tell me which one to get. i also need to get me a little bit of storage to add on to it. here is a pic... these mirrors are just some a friend had laying aroud and are just temporary till my bar end mirrors get off the slow boat.Attachment 7590
model number jtr279.35 - http://www.oldbikebarn.com/Motorcycl...?search=JTR279
beat me to it dan. anyway, http://www.jtsprockets.com/catalogue/sprocket/jtr279
Aluminum sprocket available here with a choice of tooth count: http://china-moto.com/cm/store/#ecwi...roduct=9542990
