Evokid 8 , I like the gas tank! Was it a straight fit?
Mixmaster
Sure was, Yamaha xs650 tank, sits lower on the frame so it's a lot more flush, 3 gallon capacity.
EVO! totally stripped & boss. Tank ? You should teach us more.
Love the bike, Evo. It looks great.
evokid8
Good look for sure. Do you know what year xs650 it was off of?
ghost1133
79 but I think their almost all the same
Next three days will be taking a road trip with 18 Harley guys. Couple hundred miles to a lodge. Fishing, poker & beer.
They like the DF! I hope my upper speed won't be an issue. Other than winds, perfect weather. Glad I have the pony bags & a break down fishing gear. Let you know Monday how the DF does.
GUN ROD
Sounds like a good time. Enjoy!
Newbie to biking question.
I have a new tank lined up for the df , it has 2 built in petcocks that are vacuum operated. Can i plumb them in to the df and get the to operate, or should i just set them on prime and run them into the df petcock?
Cheers
Mixmaster
Cheers
If you removed the air induction system (that lets air into the exhaust valve area) you will have a vacuum take off point available on the carb, to connect your vacuum petcock to.
My Yamaha 250 has a triple tap on the carb, for fuel pump,vacuum petcock and (disconnected) air induction. So.. you should have enough vacuum to operate dual petcocks.
