The aluminum clutch lever assembly it self cracked. Ill see if I remember to take a picture of it if I remember. Yea the weathers nice but right now it's raining. So lets see what tomorrow brings?
Mine without the tank cover
http://www.youtube.com/watch?v=gurllgY_SUg
Attachment 10126
Attachment 10127
Here's the photo.
That looks pretty messed up. What is your plan to fix it? I wonder if you could connect the jumpers on both safety switch wires together and use a generic clutch lever??
As for my clutch lever problem, I got some steel inserts of the same size thread as trhe housing originals that im putting in after I drill and retap both holes. I should be able to crank it on the handlebar halfway tight after that.
BTW, Thanks everybody who replied about my request for chrome turn signals, headlight and speedometer. I picked some up so i no longer need them.
Welcome Crelow, I like really like your Black turns and Headlite looks good with the blue. Strange how they are all a bit diff.
Bet the Clutch lever was damaged and pre cracked in shipping to the US before you got it.
Any early Honda from the 70s lever housing is about the same and should work. But that does not help with all the switches. Id order a new one while your away.
Ive done a few simple Farkle mods is all lately. I found a nice fitting chrome fork center screw cover that came in a 2 pack for yamaha side fork bolts that fit the center Bolt perfect. My buddie used the other one on his DF. I Made a polished aluim exhaust insert for the inside of tip
( I dont really know if I like the chrome look on the inside of the exhaust that much though) installed my grips, helmet lock, and a few minor other things. Ill post pics and more info later. I did install my high speed jet changed out the 88 for a 105, damm that made my bike run good. Im going to throw in a 45 idle jet in next and see if it warms up a bit quicker, too cold blooded yet. Revs super smooth now after re-tweaking the carb idle and air mix screw. Still love working on this simple bike.
Anyhow glad you joined the DF crew Crelow!:thumbsup:
I guess the perch is seperate, dahhh. The bolt holes of a old honda perch should match perfect.
I just got an exhaust heat sink finned ring from a old 72 honda rebel and the manifold bolts are spaced the same as an example. I will install it asap.
Did your buddy swap his jet out too, or did his carb have a better stock one? My bike runs premo the way it is. BTW, does your buddy bike have chrome or black headlight, etc? I wonder if they went to black from chrome on the DECEMBER models when they changed the carb jet??
His has blacked out Tail lite and turn sigs and speedo. Its a DEC 2010 build His also had the 105 bigger main jet so we only had to unclog his idle jet as his bike would not start.
Mine was a Nov build with Chrome everything but it had the smaller jet of 88 so I put in a 105. Is yours a Dec or Nov build? Also the Dec Builds have a large triangular plate welded in above the fake oil tank on his frame. he also had a front fork brake oil line bracket on his fork, mine did not so I made one. Let us know.
Here are a few new photos of dress up stuff for the DF. The chrome exhaust insert and the chrome frame cover and the seat bracket chrome is made from 1/32 thick soft aluiminum I got from innovative hobbiy supply. It can be polished with rubbing compound/ washed with soap and hot water/ cut to shape and then bent just by finger pressure and then mounted with 3M outdoor mounting tape. The stuff looks pretty amazing. I will post the stock number of the sheet supply when I find it. They also sell a adhesive backed ez chrome kit for plastic parts that is way thinner, this is not that but
about 1/32 thick and so soft it cuts with just a scissors like butter and polishes to a chrome finish. One can get pretty creative here. The Fork bolt cover kit is made by Star and is for Yamahas. I havent installed the exhaust piece yet as I dont know if I like the way it looks? Attachment 10128Attachment 10129Attachment 10130Attachment 10131Attachment 10132
Attachment 10133
Billet Fork bolt cover comes in a 2 pack for about 40 bucks, great if you have someone that wants one. i installed one on my bike also.
