chruk bashre
as i was pacing around thinking about the crankcase breather hose,
it must suck air, that is why it is now on the airfilter, the hose
will suck the air out so the new bikes dont run so lean.
I believe that it "breathes" meaning that as the pistons go up and down, the air within the crankcase also expands and contracts and therefore sucks and blows as it runs.
chruk bashre
Attachment 10223
camera battery died at this pic. not much detail to see.
started to think gloss black may go back on.
those are the bobber bars.
Those are the bars that come on all the 2010 models. I have a set in chrome if you want them. I personally would not put my life behind a set of bars that were welded in the center.
freezerboy
Sounds like a chic I once knew!
skullworkz
the first thing i noticed when my df arrived was that the bars are not welded in the middle.
i was jumping with glee.
Anyone else have any idea if the headlight is a 3 or 5 wire configuration?
skullworkz
Three wire= high,low,ground,hard wired into 35/35 watt bulb socket. NOT a H4 plug.
I attempted to upgrade mine,while I owned it.
SR.MAILMAN
You "attempted" to upgrade? I want an H4, but its a 3 wire. Are you saying this cant be done?
skullworkz
So, can I hard wire it in? This is the light http://www.ebay.com/itm/Round-4-Head...50696050003%26
