slabo
Felix, have you tried OruxMaps? I use it on my HTC Hero. You need the latest Mobile Atlas Creator 1.8 release to be able to build maps for OruxMaps. In settings, you must set max map size to 1048575, or map images are too fragmented and your Droid will crawl.
Turn by turn is useless for China, roads change too much. I plan my route on Google maps, then export to KML (press link, then add output=kml, and you get a kml file!). Then i load the KML in Mobdac, then build a map around those waypoints. I add more detail when my route passes through cities.
