I drink to that! :goodtime:
The 650TR has the mounting tabs pre-welded on the underside of the swingarm both sides, to accept the fitting of the "mounting posts" for the bike/motorcycle race (paddock) stand... the "mounting posts" are needed to be purchased separately and are available on Taobao for between 元20-70 per pair. A centre stand is not something that can be easily fitted to the 650 due to both the placement of the muffler catalytic converter collector box, and the inherent design of the engine being a stressed member of the frame. Meaning there is no frame bosses running under the engine that could be used to mount a centre stand.
I bought the TR and a paddock stand at the same time.......job done!
Forgot to mention that you best check the swing-arm to see that it has the lugs or prefabricated & threaded mounting points for the bobbins as there has been one 650TR in one thread or another here on MCM which it was determined didn't have aforementioned mounting points on the swing-arm which came as a surprise.
Thanks bikerdoc. Have fitted the bobbins. Now to search for a rear paddock stand. The first one I got, the mounting hook got bend after few uses.
